-   -   Scuff marks hardwood floors PICTURES INSIDE (http://www.diychatroom.com/f5/scuff-marks-hardwood-floors-pictures-inside-45211/)
Ineedhelp2009 05-25-2009 11:29 AM
I just purchased this home last year. Built in 01 The floors are real. From the buckets left behind there stained with poly on top. The whole house is hardwoods.... is there any solution other then sanding/restain? I have tried murphy's one time. And used bruce at least 6 times. (mistake had about 12 kids running haywire for a few hours with shoes on)
http://i241.photobucket.com/albums/f...7/IMG_1861.jpg
http://i241.photobucket.com/albums/f...7/IMG_1864.jpg
http://i241.photobucket.com/albums/f...7/IMG_1865.jpg
DangerMouse 05-25-2009 11:37 AM
i've had success with 00 fine steel wool buffing the spot off, then polishing/buffing with a towel as needed.
then the sign went on the door to remove shoes.
DM
DangerMouse 05-25-2009 11:40 AM
oh, and a friend of mine swears by tennis balls. i just never had any around to try them, though it seems it'd scrub the scuffs off ok.
DM
Ineedhelp2009 05-25-2009 12:06 PM
DM
Thanks will try in a spot and see the outcome, but That's a whole lot of work! it's about 2500-2700 square ft of hardwood floors and about 85-90% is messed up
shoes off for now on.
Shamus 05-25-2009 03:14 PM
The word you don't want to hear. Refinish.
Once the color is gone from a scratch that's the correct solution.
I've seen attempts at spot refinishing and that what it looks like when they finished.
Once you re-do the floor buy a supply of throw rugs in traffic areas.
Ineedhelp2009 05-25-2009 03:47 PM
I was thinking that was going to be the answer. Alot of the stain has been chipped off... really bad by front door. So in a cases like that...do people normally take quarter round up, and put back or do new. If so how to you get it off without scratching floor. I have never done floors before, is this something the average person can tackle myself (renting big sander or pay someone?
Shamus 05-25-2009 05:41 PM
I like to remove the qtr round. It allows you to get close to the base and makes for a better finished job. Especially in the corners. Just pry it gently and use a thin backer to keep from marring anything. Then re-install. If it needs some sanding and painting do it before you replace.
It's a DIY project but do your homework. Research what types of sander and grit will be best for the wood type and floor finish you have. Better to take off less with more passes with the sander than trying to rush the job. You may need to stay with the same shade of finish. It may be unrealistic to change to something lighter because you probably won't be able to remove all the dark color from the wood.
I'd start with verifying how thick the wood actually is. If you can pull up a threshold or a floor register to see the end-grain you can confirm what your working with.
Ineedhelp2009 05-25-2009 05:51 PM
Sounds good.....good input... that will be a really long project my house has alot of funny shapes and angles everywhere almost shaped like a octagon
the wood is really thick i have been able to pull a piece under the steps i would say at least an inch.
DangerMouse 05-25-2009 06:05 PM
an inch thick? was that built in 1901? or 2001?
i'd dare say before sanding, be sure it's solid hardwood, not a laminate!
DM
floortrends 05-25-2009 06:14 PM
Without experience I would be very hesitant to sand and finish a floor that size with a 110v rental machine. Your house would be out of comission for weeks. When you sand your floor you will remove all the stain and end up with a natural floor again. That should be your goal. If you do decide to take on this project, I would recomend not staining the floor. It takes many years of practice to acheive a stained floor without uneven shading. Also next time don't use oil based poly, use a more durable finish like Bona Traffic.
Ineedhelp2009 05-25-2009 06:38 PM
DM
This is on piece i can remove under steps next to air vent... not as thick as i was thinking
http://i241.photobucket.com/albums/f...7/IMG_1866.jpg
floortrends 05-25-2009 06:41 PM
That is 3/4 solid red oak
Ineedhelp2009 05-25-2009 06:44 PM
good?bad?
floortrends 05-25-2009 06:47 PM
That is fine. You have plenty of wood to sand.
DangerMouse 05-25-2009 06:51 PM
for sure oak, likely a dark walnut stain. will require much sanding to get it back to light color and even.
DM
