Screwing In Threshold - Flooring - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 12:25 PM   #1
Rewards Points: 27
screwing in threshold
Question, I'm putting wood (oak) thresholds into a room I recently put flooring in. I imagine given the openness of an (indoor) threshold, that I'd want to hide the screw heads.
Is this something deserving of a counterbore? (which, based on my reading are usually filled in with wooden plugs. I plan on only using wood putty.)
Or, can I expect to just be able to sink a screw deep enough with a pre-drill hole and a little pressure.
Any suggestions appreciated, and recommended screw sizes/types?
bamaranch is offline   Reply With Quote
Old 12-29-2012, 12:38 PM   #2
Rewards Points: 13,712
Use a bit like this sized according to the screw size you plan on using and use a wooden plug not wood filler.
By using a wooden plug and paying attention to the grain in the threshold and in the plug once sanded off it will be near invisable, putty will stick out and not take stain like a wooden plug will.
Old 12-29-2012, 02:35 PM   #3
Rewards Points: 558
use a counter sink bits like these with a wooden oak plug http://www.toolstoday.com/c-355-carb...FUZgMgodVF4AHw
glue the pug in place following the grain of wood after inserting the screw, sand flush and stain.
epson is offline   Reply With Quote
Old 02-10-2013, 02:11 PM   #4
Rewards Points: 27
Fell asleep on that job again, but picking it back up. Thanks for the advice. A question I have now is whether I should do this on a threshold product that is only 3/8ths of an inch thick itself. Is that too thin of a board to try to counterbore?
I noticed on this video http://www.popularmechanics.com/vide...deo-1828663337
that he sunk the screws 3/8 deep. I assume I need enough room for those plugs to catch. I'm wondering if my threshold board is only 3/8ths if I've got enough wood to work with.
Old 02-10-2013, 03:28 PM   #5
Not going to work, to thin.
Pl adhesive and finish nails is the way to go.
Replace threshold? thaKing Windows and Doors 4 07-17-2012 11:27 AM
Door Threshold question jakeclev Windows and Doors 1 03-17-2012 03:14 PM
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 01:20 PM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 05:36 AM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 07:16 PM
