Screwing Down Subfloor & Crowned Joist? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 01:59 PM   #1
Screwing down subfloor & crowned joist?
I will be installing a 3/4" maple floor this week over 3/4" plywood, in a home that is 14 years oldand has some minor squeaks in it. It is screwed down now but I wanted to add some more screws, should I put them right beside the old ones or in the middle between them?
I also have one floor joist that is crowned about 3/8" in a low traffic area, I have very limited access to get to it from underneath. An installer where I bought the wood just said to take the crown down with a belt sander and then shim it if necessary.
Any info greatly appreciated!
Thanks!
roar24 is offline   Reply With Quote
Old 03-20-2011, 04:27 PM   #2
The answer will depend on your floor. I have had some needing just 1 screw/nail and that took care of a squeek, where as some areas are more squeek prone.
Have fun.. the best way is to fix it in part from under the floor.
IceT is offline   Reply With Quote
crowned joist / uneven floor shawn99 Flooring 22 01-13-2010 02:11 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
Crowned Floor Joist Thirdeye Carpentry 4 03-04-2007 04:55 PM
