Screwing Down (specifically) Fiberock - Flooring - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 10:55 AM   #1
Question
Screwing down (specifically) Fiberock
So, I'm installing 300 sq. ft. of Fiberock per the manufacturer's instructions (thus far), and according to USG, the screws don't need to be flush to the surface of the board:
Drive nails and screws so that bottoms of heads are flush with panel surface to ensure firm panel contact with subfloor. Do not overdrive fasteners.
My question/concern is all other backer board manufacturers and DIY posts seem to indicate that the tops of the screws need to be flush with the panel surface. I'm going to be laying porcelain tile over the Fiberock using thinset.
Who do I believe—manufacturer, or everyone else? I'm thinking the thinset will gloss over the 1/32" to 1/16" of screw head sticking up above the backer board, but I'd like a second opinion.
garbonsai is offline   Reply With Quote
Old 02-10-2012, 11:17 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
I went thru the lit and couldnt find where it says that.
Believe everyone else and make the tops flush with the board.
12penny is offline   Reply With Quote
Old 02-10-2012, 12:05 PM   #3
Page seven of the brochure:
Fastening
Fasten to subfloor with 1-1/4" Durock tile backer screws for wood framing (or equivalent) or 1-1/2" hot-dipped galvanized ring shank roofing nails spaced 8" o.c. in both directions with perimeter fasteners at least 3/8" and less than 5/8" from ends and edges. Drive nails and screws so that bottoms of heads are flush with panel surface to ensure firm panel contact with subfloor. Do not overdrive fasteners.
I'm not questioning your advise—just explaining where I found it. Any thoughts?
Old 02-10-2012, 12:26 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 412
Or..... why not use the roofing nails? Much faster, cheaper, work great cuz you're likely to use more, no bumps. They do not have to be the ring shank type, which I'm not sure where to find. Don't skip the thin set under the panels and tape the seams etc.
Jaz
screwing hardiebacker on top of subfloor amakarevic Building & Construction 10 04-12-2011 11:40 PM
Fiberock for tub enclosure Kfan Tiling, ceramics, marble 1 09-25-2010 09:44 PM
Not Screwing Board Edges in Wall Corners? TomBrooklyn Drywall & Plaster 3 01-16-2010 10:53 PM
When to tape the fiberock....? Curio Flooring 2 01-29-2008 11:18 AM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
