-   -   Screwed down Sub Floor, but still squeaking? (http://www.diychatroom.com/f5/screwed-down-sub-floor-but-still-squeaking-39764/)
rlc2052 03-06-2009 01:11 PM
I have a 5' X 7' squeak in the middle of my bedroom. I removed the carpet, then screwed down the 5/8" sub floor to the trim joists every 6". Unfortunately the squeaking is still there. There are no gaps in-between the sub floor boards. Also I have trim joists that are spaced out every 26". What would my next step be in figuring out what the problem could be?
Thanks,
Robert
JazMan 03-06-2009 02:02 PM
You didn't say whether you have access from below. I would look for a nail that just missed a joists and is sticking out next to the joist. What type and size are the joists? And you say they're 26" on center? Are you sure?
Jaz
rlc2052 03-06-2009 04:56 PM
The joist dimensions are 11.25" X 3.5" They are 15' long. They are actually 24" on center. SpaceJoist is the manufacturer of the joist. My bedroom is above another room, so I would have to do a lot of sheetrock work to get to it from underneath.
Robert
JazMan 03-06-2009 07:12 PM
OK, so you did your best by re-screwing the subfloor, how else are you gonna get to the trusses? I can see how that type of truss could squeak from the way they are built.
Have you tried to listen if the noise is coming from the subfloor sheets or the framing?
Jaz
fixrite 03-06-2009 07:18 PM
I agree with Jazman, in my last house I had to remove the nails that were there to finally get rid of the problem. A good nail pulled did the job in about a half hour. Very satisfying.
cheers
rlc2052 03-07-2009 10:11 AM
I have tried to listen, but it is hard to tell where it is coming from. It could be coming from the joists. I think pulling the nails in that area will be my next step.
Thanks for the help.
rlc2052 03-08-2009 09:23 AM
Well, I pulled out all of the nails in the area and still have the squeak. I am going to pull up one of the subfloor boards and see if I can find it that way. The problem is that the subfloor was glued down to the joists. I am a little worried that I could damage the joist if I pull the boards up. Does anyone have any suggestions?
alexcooper 03-08-2009 10:07 PM
I have the same problem in my living room, which are hard wood floors. How would I fix the squeak without seeing screws or nails? I do not have access underneath.
rlc2052 03-09-2009 11:08 AM
I finial found the squeaky nail!!! It was actually coming up from a nail in the sheetrock ceiling underneath. I ended up cutting a hole in the sub floor and found it. I was going to put down another layer anyway.
Thanks for all of the help.
Hey Alex,
One thing you can try the Squeak No More Hardwood Floor Kit from Mcfeely's. It did not work for me, but my squeak was from a nail in the ceiling instead of the floor.
fixrite 03-09-2009 11:42 AM
Glad to hear that all of your squeaks are gone. It is just a nail pull away.
cheers
JazMan 03-09-2009 12:49 PM
See......I told ya! :thumbsup:
Alex,
You first have to determine whether the squeak is from the subfloor or the hardwood. Which is it?:whistling2:
Jaz
alexcooper 03-09-2009 08:22 PM
Thanks Robert,
I didnít know about the Squeak No More Hardwood Floor Kit.
Jaz,
How would I determine whether it was the sub floor of the hardwood?
JazMan 03-09-2009 09:21 PM
Well...first determine the type of hardwood, thickness and how it's installed. Get your ear close to the floor and have someone cause the squeak. You may be able figure it out. If it is the hardwood rubbing on its self, we often sprinkle talcum powder and brush into the edges. This might work. OR.....face-nail the hardwood with finishing nails. Drill a small hole, drive nail and countersink, fill with wood putty. :thumbsup:
If it is in the framing, out course you'll have to operate.
Jaz
alexcooper 03-09-2009 09:26 PM
Thanks Jaz, I'll look into it. Hopefully it's a simple fix. However I have a feeling it's going to be more involved.
rusty baker 03-09-2009 10:17 PM
Floor squeaks became more common with the use of air tools. When nailing the plywood, you can't tell by feel whether you are hitting the joists or not.
