Screw Down Subfloor While I Have The Chance? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 10:08 AM   #1
Screw down subfloor while I have the chance?
I'm taking everything down to the subfloor (OSB) in my house (built 10 years ago) in order to install laminate flooring. Question is, should I use this opportunity to reinforce the already nailed down subfloor with screws? If so, what type of screws?
Thanks for all the great advice on here. Any feedback is much appreciated!
rowdruner is offline   Reply With Quote
Old 02-26-2012, 10:14 AM   #2
Rewards Points: 528
Do you have squeaks?
If you don't, why bother?
framer52 is offline   Reply With Quote
Old 02-26-2012, 10:28 AM   #3
I don't what what kind of screws to use, but I know for sure don't use cheap screws from the big box store.
Hardway is offline   Reply With Quote
Old 02-26-2012, 10:29 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
You can always do it in a few years when you pull the laminate like most people do.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-26-2012, 10:32 AM   #5
Rewards Points: 528
That makes no sense.
Old 02-26-2012, 10:41 AM   #6
Yes it does, I use/used the screws from the box store and the heads pop off. In old construction hard wood they are terrible. GRK screws are supposed to be high quality, you wont find them on the big box store self.
http://www.acmetools.com/tools/GRK+Fasteners
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Old 02-26-2012, 10:47 AM   #7
Rewards Points: 528
sorry but you can. I have bought at HD I believe.
Second if the heads are popping off and you are using the correct screws for the application, then you are tightening them too much.
Shoot, I use an impact driver and I can't remember the last time I had a screw head pop off.
Old 02-26-2012, 10:52 AM   #8
well there ya go, i stand corrected!
Old 02-26-2012, 11:35 AM   #9
Thanks all! As always, great dialogue on the topic No squeaks in my floor. I'm actually surprised because it's a total cookie cutter house and a lot of corners were cut.
Honestly, I didn't know people pull laminate after a few years. Something to keep in mind. And I'm guessing "box store" refers to home depot or lowes? That's the only hardware place I know of! In such an amature, but slowly learning thanks to you all!
Old 02-26-2012, 12:08 PM   #10
Rewards Points: 182
In my experience, carpet, laminate, vinyl planks and IVC type vinyls, all have a lifespan of 5-7 years. Engineered wood maybe 10 years. Ceramic 25 or more. Hardwood, 100 years or more. And yes, Lowes, HD, Menards, etc, are big box stores.
Tags
screw osb , subfloor
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 07:48 PM
Breakers that could take 2 wires under one screw latinomusician Electrical 25 06-24-2010 06:19 AM
Help with Screw sizes needed! andyroo77 Building & Construction 5 06-02-2010 09:00 PM
stripped shower screw betsylwhs General DIY Discussions 2 12-28-2009 08:33 PM
Would you staple, nail or screw? Speedball Flooring 7 11-28-2008 11:21 AM
