Screen & Recoat, please help!
If you have some dull areas and some shiny areas, the problem is likely 1 of 2 things. The floor wasn't abraded properly (probably not the case since you used a 120 screen, rather than the 220 you should have), or the floor has wax or shellac on it and their were bonding issues. Many times floors of this age will have shellac or a wax on them. New polyurethane's will not successfully bond to these. This is probably the problem.
The solution at this point is to buff the floor again after the finish you put down is completely dry. I would use a 150 screen. You will want to try to take most of the finish you put on the floor off of it. Then clean, vacuum etc and apply a universal sealer such as duraseals, or Parks pro finishers universal sealer. This will help the coating bond. After applying this, it's not necessary to buff again, just let it dry, then coat with a polyurethane. Make sure before applying the universal sealer that the floor is very clean.
When doing the buffing of the floor if you have areas that still look shiny, then the floor is not abraded well enough and this stuff will show through.
You can probably make these floors look alright, but honestly if they are this old, I can tell you without even seeing them that the right thing to do is a full sand and refinish.
