For some reason, what you're wanting to do just feels like your going to have failure.I don't have a ton of experience with water based finishes, but I did attend a seminar on recoating with water based finish. The recomendations of that seminar were to use a bonding agent when recoating over polyurethane or aluminum oxide with water borne finish.
If you decide to go with oil based finish, I'll be able to offer a lot more advice. I've got a lot of experience to draw from there.
Originally Posted by Bob Mariani
it will work if the floor indeed does not have significant scratches. You may not be seeing them until you apply a new coat. Wipe the floor with mineral spirits. This will show what it will look like with a new coat. If not acceptable you will need to use a sander, not just the screening
Mineral spirits & water based finish are not a good combination. I do exactly what you desribe to give clients an idea of what they're floor will look like, but I use oil based finish.
