Old 10-13-2012, 09:01 AM   #1
screen porch flooring
we are building a house with a screened in back porch that will sit 9' above the ground. Do you recommend tongue and groove wood flooring? We were thinking of Ipe. Porch will be right next to deck so want to use same material for both. Will tongue and groove separate over time?
hyldgrp is offline   Reply With Quote
Old 10-13-2012, 09:10 AM   #2
Have you priced out the IPE yet?
It's about the most stable wood you can buy so it's not going to shrink very much if at all.
I would use the groved 5/4 decking instead with hidden hangers. You want the water to run out of the decking not sit on top of it or in the small gaps like T & G would. If you went with T & G IPE you would have to predrill every single hole.
Tongue and groove porch flooring cambishop Flooring 7 08-24-2012 10:56 PM
Screen porch over deck gardengal_mad Building & Construction 1 03-23-2012 04:11 PM
Porch railing and screen miamicuse Carpentry 5 03-01-2012 07:55 AM
Screen Porch Base Posts Packer Building & Construction 8 01-16-2012 06:30 PM
porch flooring at top of steps shtoink Building & Construction 1 03-05-2010 01:07 PM
