Old 06-06-2011, 10:59 AM   #1
Scratch Coat
Good morning all.
I have a 1 year old kitchen floor with builders cheap ceramic tiles. My wife wants tumbled marble, which I can do, but I'd like to know if I have to remove the scratch coat or can I simply lift the tiles and stick the new ones on top of it?
Thank you
Speed3C is offline   Reply With Quote
Old 06-06-2011, 07:21 PM   #2
Tileguy
Bud Cline's Avatar
Scratch Coat
What is there now is not known as a scratch-coat. That's a different building product and process.
What is there is more than likely thinset mortar. Once you remove the old tile the resulting remaining mess you will have will not be suitable for new tile without some additional preparation.
Is this subfloor wood or concrete?
If it is wood you should first know that most floor structures aren't suitable for a stone tile installation such as marble. Marble requires a floor structure that is twice as strong as that required for ceramic tile.
If you will provide us with your floor structure criteria we can check it out for you.
We need the size of the floor joists and their wood species if you know it.
We need to know the spacing of the floor joists.
We need to know the unsupported span of the floor joists.
We need to know the thickness of the subfloor and what it is made of (plywood, OSB) and how many layers of subfloor are there.
Old 06-07-2011, 04:50 PM   #3
Scratch Coat
I have plywood. The studs are 16 inches apart.
What would I need to do to reuse the thinset I have?
Old 06-07-2011, 05:49 PM   #4
Stuck in the 70's
Blondesense's Avatar
Scratch Coat
You really should make sure your subfloor can handle it before proceeding.
Bud taught me a lot when I was trying to tile a couple of projects.
You gotta help him help you though. Answering ALL his questions would be a start.
BTW, have you tried to "simply lift the tiles"? If you haven't, and if the builder did everything right, you may find it ain't gonna be that easy.
OTOH, if you think it will be easy because you already have loose tiles, that can be an indication your floor is inadequate.
Blondesense is online now   Reply With Quote
The Following User Says Thank You to Blondesense For This Useful Post:
DangerMouse (06-09-2011)
Old 06-09-2011, 08:58 AM   #5
Tileguy
Bud Cline's Avatar
Scratch Coat
Well Speed,
That was real helpful.
If you don't care then neither do I.
The Following User Says Thank You to Bud Cline For This Useful Post:
do i need to use a scratch coat and wire mesh on cement board(floor) Limit54 Flooring 10 12-03-2009 07:24 PM
Cracks in stucco scratch coat - is this normal? chadurban Building & Construction 5 05-25-2009 11:55 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
