SCL HELP!! With Ditra - Flooring - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 10:38 AM   #1
Hermie's Avatar
SCL HELP!! with Ditra
First off, thanks for reading my question
I have a bathroom I am preping for tile, and yes I have a couple of smiles in the floor, so I have purchased some Stone Mason E-Z flow SLC. Now I'm sure I have everything figured out on how to do it all, but after the floor is level I will be also installing Ditra, so here is my question
Schluter instruction says to lay min. 3/8 underlayment and with 1/8" spacing between sheets and walls (which is complete) so my thinking is once I pour the SCL all the spacing will be filled in! is this an issue? Should I fill the gaps with a flexable chaulk or something?
I hope you DIYers and Pro's have had this issue, and know the correct way to deal with it, as I can't find anything on the Schluter, nor the Stone Masson site regaurding this issue
Thank you
Josh
Hermie is offline   Reply With Quote
Old 05-01-2010, 11:06 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 240
Hi Josh,
It shouldn't be an issue in a small space, but it's best to leave an expansion joint. Use self-stick foam bonded to the wall.
Jaz
Old 05-01-2010, 11:45 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Or run a bead of minimal expanding spray foam.
poppameth is offline   Reply With Quote
Old 05-01-2010, 12:17 PM   #4
Hermie's Avatar
I do need to fill a gap under my tub (to stop the SCL from going under it) So I have some small gap fill foam (for chaulking large gaps) I was going to use for that, do you think this will work around the wall gaps?
Thanks for the replies
Josh
Old 05-01-2010, 01:38 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 240
No.
Jaz
Old 05-01-2010, 05:53 PM   #6
Hermie's Avatar
Originally Posted by JazMan View Post
Hi Josh,
Jaz
By that are you meaning plain old weather stripping (foam with the addhesive strip on the back)
Thanks for the help Jaz
Old 05-02-2010, 04:20 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes. Also run a strip of the adhesive across the front of the tub. Be sure it is firmly touching the floor in all areas but especially in front of the tub. The SLC won't creep under the foam and you'll be fine.
After the SLC sets up use a utility knife and run it along the top of the SLC to cut-away the foam everywhere. Maintain a 1/4" gap between the tile and the walls and reduce the gap to 1/8" along the front of the tub. Later caulk the tub gap.
XXX
Do you absolutely have to use Ditra? Quadfam4 Tiling, ceramics, marble 31 12-22-2014 07:21 PM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
confusion over thinsets for installing Ditra over heated flooring fhknox Flooring 12 01-19-2009 07:21 PM
Ditra vs. Ditra XL richbl Flooring 3 10-13-2008 10:07 AM
To Ditra or not? JamesEric Flooring 20 02-24-2008 11:42 AM
