Schluter Strip Between Tile And Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 06:28 AM   #1
Schluter strip between tile and carpet
We aren't sure if we should use the schluter strip. The tile will be higher than the carpeted area so we got the schluter strip that embeds in the thinset under the tile and has an overhang that slopes down over the carpet. Problem is, we will be putting in new carpet once the kitchen reno is done. Will the schluter strip be a problem when it comes time to insall new carpet? How easy will it be to tighten the carpet under that sloped overhang of the schluter stip? I guess I'm concerned because once the schluter is in, it's in. We are also considering carpet shims to bring the carpeted area up to the tile area. Any thoughts on those? We've never used them before.
kidsncats is offline   Reply With Quote
Old 05-01-2012, 04:05 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
You're probably using this.
http://www.schluter.com/p/content/ss...289x193_80.jpg
Use this instead and shim or tuck the carpet if needed.
http://www.schluter.com/p/content/ss...290x191_80.jpg
Jaz
Old 05-02-2012, 06:29 AM   #3
Thanks Jaz. You're right, the first one is what we had planned on. Now I'm thinking of not using either. Watched a couple tutorials on youtube about carpet butting up to tile and looks like a nice seam can be made without a transition. What would you do?
Old 05-02-2012, 11:11 AM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
The one you were thinking of using is mostly used for glue-down commercial carpeting. I would use the standard Schiene piece and the carpet installer can stretch and tuck to it. That's the best look, IMO.
Jaz
tile to carpet transition billyg Flooring 1 09-23-2011 11:09 PM
Where tile meets carpet FirstAndTen Flooring 2 02-17-2011 06:20 AM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 12:55 PM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 12:28 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
