Schluter Ditra Installation Question - Flooring - DIY Chatroom Home Improvement Forum
Old 09-25-2010, 07:23 PM   #1
Schluter Ditra installation question
OK,
Got a bathroom we're working on. We installed a radiant floor heating system which is covered by a layer of mortar. My father tried to level the rest of the floor with hand troweled mortar; he did a decent job but the floor still has some valleys and high spots and is far from a smooth surface. He's convinced we can level it with mortar as we go through with the installation of the ditra. i'm concerned that attempting to level it durring the ditra installation will result in less than satisfactory results... My idea is to use a thin layer of self leveling concrete to fill in and level this in preparation for the ditra... He's concerened this will build up the floor too much as we're trying to avoid a drastic transition between rooms...
Any guidance is greatly appreciated!
epsilon is offline   Reply With Quote
Old 09-25-2010, 10:21 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Hi Epsilon,
SLC is the way to go. It'l only raise the floor a bit higher than the peaks. Remember to follow directions and that it does not really just level its self, it needs a little help.
Jaz
Old 09-25-2010, 10:25 PM   #3
That's what i was thinking... Dad's smart and all but stubborn as hell when he gets somthing in his head... not that i'm that way
Old 09-25-2010, 10:34 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 290
Of course..........
His way will not work so good. It's impossible to know exactly where and how much extra thin set you'd need. Plus you have to "beat" or push the Ditra into the mortar as you lay it not to mention walking on it, which would make a real mess. You have to do any flattening of the floor first, especially with a membrane.
Jaz
A question about interior door installation Richo Carpentry 3 09-07-2010 09:35 PM
3/8" Drywall Installation Question pjmachine Remodeling 10 02-27-2008 06:07 PM
Soffit installation question milano Roofing/Siding 4 02-04-2006 11:13 PM
Wood Burner Installation Question? fisher501 HVAC 1 12-22-2005 10:29 PM
