Saw Blade For Tarkett Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-03-2014, 03:45 PM   #1
Saw blade for Tarkett laminate flooring
I was wondering if anyone could recommend a good saw blade for cutting laminate flooring. I know that the flooring has a hard coating that dulls a regular blade in a short hurry. I have seen blades specifically made for laminate but didn't know how they would hold up. Also can those blades be used for trim too, or are they just for laminate.
rpregs is offline   Reply With Quote
Old 10-03-2014, 07:19 PM   #2
Rewards Points: 12,790
Any sharp blade will cut it, just flip it over for less tare out.
Most of the time I use an 80 tooth blade on a 12" saw.
A 10" saw is useless.
Old 10-04-2014, 12:53 PM   #3
Are you suggesting to run the blade backwards or to cut the flooring upside down for less tare out
Old 10-04-2014, 01:08 PM   #4
Rewards Points: 144
I run a 12" 80T carbide blade turned around backwards for a few things like vinyl but have not found the need on laminate.If your worried about tear out a piece of masking tape or painters tape on the cut line will help.Also makes your cut mark easier to see on darker flooring.
mako1 is offline   Reply With Quote
Old 10-04-2014, 08:11 PM   #5
Rewards Points: 90
With a ten or twelve inch miter saw will do just fine. Turn the BOARD
Upside down to minimize tear out. Ron
ront02769 is offline   Reply With Quote
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 10:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 05:39 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
