Saw Blade Recommendation For Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 09:09 AM   #1
Saw Blade recommendation for Laminate Flooring
I the next year I will be putting down 1500-2000 sq-ft of laminate flooring. I have a 12" Miter and 10" table saw. Any recommendations on blades. I am more concerned with blade life. I have carbide blades with 60-92 teeth .I thought I read somewhere that they made a special blade for laminate that the teeth are different. I can use the blades I have but probably that much flooring (Mohawk they said was hard on blade) i can save my trim blades and get a special one for laminate. Any thoughts appreciated.
thanks
bowbender6 is offline   Reply With Quote
Old 07-01-2011, 09:52 AM   #2
DIY staff
Rewards Points: 7,174
Laminate flooring will ruin a blade in seconds----save your good ones for the trim.
All cuts are hidden by trim so cut quality is not terribly important.
Use a medium quality (read cheap ish) blade----I like to use a cutting box and a Skill Saw--but if you don't mind forking out for a couple of 12" blades then use the chop saw.
Wear goggles when cutting---those chips are very nasty --Good luck---Mike---
Old 07-02-2011, 12:44 PM   #3
personally, I would use 1 good blade on the table saw and invest the balance on a laminate cutter. Alot less mess/dust and no running to and from the worksite to the saw (creating laminate dust around your installation area is worse than drywall dust!). DON'T FORGET THE KNEE PADS!
HarryJ is offline   Reply With Quote
Old 07-03-2011, 12:44 PM   #4
Which laminate cutter?i have tried the one with a small saw bladeat home depot, and I have seen the one that has a big blade,i think both are around $50
Old 07-03-2011, 01:52 PM   #5
Rewards Points: 482
thanks
Check this web site and you can get so pointer's. http://www.carpentry-tips-and-tricks...-flooring.html
del schisler is offline   Reply With Quote
Old 07-04-2011, 08:34 AM   #6
Sorry Bobender,
I meant a particular tool that operates similar to a paper cutter. No power source, no rotating blades. you can buy different models for 250.00 and up or rent them from bldg supply stores, rent-alls etc. It will cut your work and subsequent clean-up in half. I've used the 'EZ-13 Shear' cutter but there's probably cheaper knock-offs out there. good luck.
Old 07-06-2011, 07:08 AM   #7
Here are the ones I have seen. About 400 sq/ft of the laminate is 12" tiles
http://www.homedepot.com/$0---$30/h_d1/N-5yc1vZ/Ntt-laminate%2520cutter/searchNav-true/h_d2/Navigation?keyword=laminate+cutter&selectedCatgry= SEARCH+ALL&langId=-1&storeId=10051&catalogId=10053&omni=%2525240%2525 20-%252520%25252430
Old 07-06-2011, 08:24 AM   #8
I bought my guys the ez shear 9 #109. below is a link with the picture of it. The 12" tiles would take an overly expensive cutter for your job and i'd probably just use a small table saw for those pieces ( you'll want the table saw for your finall cuts anyway)
http://www.bullettools.com/ProductDe...gle-guide.aspx
hope this helps....the other ones you saw may work fine, just showing what we use.
Old 07-06-2011, 04:09 PM   #9
Handyman
Rewards Points: 512
If the flooring isn't too wide you can save blade life by cutting the planks vertical against the fence on the chop saw. Laying it flat and cutting will dull the blade in no time.
canadaclub is offline   Reply With Quote
Old 07-06-2011, 05:28 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
When I was doing laminate flooring I used a 12" chop with an 80 tooth carbide blade. I tracked the blade wear and consumption for a time. On average the blade was shot after every 240 square feet of installation. A 10" table saw blade 60 tooth would last for several jobs.
XXX
Old 07-14-2011, 09:23 AM   #11
I think I will try a cheap portable table saw - Found one at Menards for $100. I may still end up buying a Bullet EZ shear. But i still have to rip the planks.
I think I will use cheap carbide 7 1/4" blades. I can get a 10 pack 24 tooth for $40. Or should I spend $5-6 and get some 40 tooth. will more teeth last longer?
Thanks all for the tips
Old 07-14-2011, 10:23 AM   #12
more teeth, better cut
Old 07-15-2011, 05:43 AM   #13
There's a youtube video of a guy "ripping" a laminate plank with the paper cutter style laminate cutter. Really, no alum oxide dust.
Wahiawan is offline   Reply With Quote
Deck flooring recommendation needed tinkertoo Flooring 8 05-07-2011 07:27 PM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 11:31 AM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 04:55 AM
Scraper recommendation for vinyl flooring removal bob22 Flooring 0 09-03-2010 07:38 AM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 06:58 AM
