Saving Old Hardwood Floors... - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2007, 01:08 AM   #1
MLO
Saving old hardwood floors...
I have been laboring with nailsets trying to save the old oak. driving the nails through the planks is leaving a "heave" around the nail hole on the backside. Is this going to pose a problem for thier re-use?
Someone told me to "cut" the nails instead of driving them through. How do you do that?
MLO is offline   Reply With Quote
Old 02-17-2007, 08:35 AM   #2
Darylh's Avatar
Have you tried to break them off with a pair of vise grips. You may find they break off even with the wood.
Darylh is offline   Reply With Quote
Old 02-17-2007, 01:34 PM   #3
Rewards Points: 77
Are they round wire nails or the flat power cleat type? Wire nails I knock or pull through the flat cleat type are better to break off.
Zero Punch is offline   Reply With Quote
Old 02-17-2007, 09:20 PM   #4
MLO
They are finish nails driven back at an angle. Very tough to drive through as I have broke a half dozen drift punches ground down.
Is this crazy trying to reclaim this flooring?
Old 02-18-2007, 08:17 AM   #5
Darylh's Avatar
Nothing crazy about saving old wood flooring if it is in good shape. If the above is not working for you then cut them off with a hack saw and use a angle ginder on any of the nails that might be left sticking out of the back.
Old 02-18-2007, 10:27 AM   #6
MLO
Maybe I am going about this wrong. I have been driving the nails through, then lifting the flooring up from the subfloor. Sounds like you are talking of prying the flooring up (nails attached), then cutting the nails off the back side of the flooring, correct? The nails are surprisingly long.
Old 02-18-2007, 10:47 AM   #7
Darylh's Avatar
OOPPS!! thought you already done that, Sorry. I know some one who used a Reciprocating saw with a metal blade and then grinded the backside afterwards and he said it worked just fine. I have removed flooring and then pulled them out from the backside and have also used a visegrip and broke them off and grinded aflerwards. The real trick to getting the boards off is not to break the tongue.
where to get 1/4" thick hardwood floors? dozu Flooring 3 04-30-2011 05:17 AM
Hardwood Floors Josh89 Flooring 10 01-04-2010 08:22 AM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 03:34 PM
Installing hardwood floors helpless handyman Carpentry 10 04-09-2007 09:23 PM
polyurethane coat for hardwood floors. christy123 Flooring 2 12-10-2006 10:20 PM
