Sanding Steps - Flooring - DIY Chatroom Home Improvement Forum
Old 03-31-2005, 07:20 AM   #1
sanding steps
I have just finished sanding and staing my living room and dining room using floor sander and a edger sander. Now it is time for the steps going upstairs. I tried one step with the edger, it semed to sand ok but will not know until I stain it. My question is, should I use the edger or vibrating or orbital sander? Any advise on sanding these steps would be great.
maintenance is offline   Reply With Quote
Old 04-01-2005, 09:36 AM   #2
aka:awesomedell
Rewards Points: 150
Send a message via MSN to housedocs
I've found a small palm sander works best on stair treads. They're always a pain though. Good luck, make sure you use tack cloths to get all of the dust out of the corners before sealing/staining. Good luck.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 03-21-2011, 01:55 PM   #3
A palm or an osalating sander works great.
IceT is offline   Reply With Quote
Question on front steps? flyerman22 Building & Construction 1 04-23-2007 06:53 AM
Steps on an umortated brick patio schott_robert Building & Construction 2 12-04-2006 07:15 AM
Dustelss Power Sanding Systems MasterStrokes Tools 14 10-12-2005 04:51 PM
Sanding previously painted woodwork MWM Painting 7 09-25-2005 10:37 PM
How to built steps that cantilever out pgs_28 Building & Construction 18 04-21-2005 11:24 PM
