Old 05-02-2007, 09:24 AM   #1
Sanding stairs
Hi all,
What is the best way to sand hardwood covered stairs? The part you step on (the tread) and more importantly, the closed riser?
Do you use a palm sander or a scraper or is there a special tool?
The stairs have a finish on them.
the pezident
thepezident is offline   Reply With Quote
Old 05-02-2007, 09:31 AM   #2
Sanding stairs
I never done it but would think it would be a mixture of Hand sanding and Orbital Sander sanding...
KUIPORNG is offline   Reply With Quote
Old 05-02-2007, 09:33 AM   #3
Master Craftsman
Big Dave's Avatar
Sanding stairs
Hand sand, scraping, orbital, whatever gets the job done with the least amount of work.
Most stair finishers use a scraper to get most or all then finish with an orbital and hand sanding.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 05-02-2007, 10:00 AM   #4
Sanding stairs
Thanks for the lightning replies
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 08:16 PM
Railing on Stairs Melanie337 Carpentry 6 10-04-2006 10:39 AM
Dustelss Power Sanding Systems MasterStrokes Tools 14 10-12-2005 05:51 PM
