Sanding Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 05:57 AM   #1
Sanding stairs
I've just ripped the carpet from my stairs and landing. I want to sand and varnish them but cant get the glue off! Anyone got any tips????
carrie35 is offline   Reply With Quote
Old 12-05-2009, 09:46 AM   #2
Sanding stairs
Take a paint scraper & drag at the glue. Does it powder, or gaum up? If it powders, it's latex & you can sand it without clogging paper too bad. If gaums up, it's solvent based & you'll need to get an adhesive remover to remove it. Be sure to ventilate the area really well if you have to go that route.
pinwheel45 is offline   Reply With Quote
Old 12-05-2009, 06:15 PM   #3
msv
Hardwood pro
msv's Avatar
Sanding stairs
pinwheel45 covered everything about the glue part. i'd like to ask about the raisers though... are you planning on sanding those too? or paint them? also what type of wood are you dealing with?
50% down, 50% after all your complaints....
Hardwood Floor Refinishing Roswell
msv is offline   Reply With Quote
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Strengthening stairs with less support HitLines Remodeling 1 10-30-2009 12:45 AM
Painted the stairs ... . kimber Painting 8 10-07-2009 12:50 PM
Sanding my stairs. Wrong equipment? Question about removing treads. Kinda long, sorry Mike in Arkansas Flooring 3 04-23-2009 02:04 PM
Sanding stairs thepezident Flooring 3 05-02-2007 10:00 AM
