Old 09-26-2010, 12:55 PM   #1
sanding hardwood
any suggestions on what's better to use an orbital sander or square that moves back and forth when redoing hardwood floors
mattrussin is offline   Reply With Quote
Old 09-27-2010, 05:56 PM   #2
sanding hardwood
Bunce had the best rental for this , BUT I WOULD NOT USE THEM AS A PROFFESSIONAL .it's the drum sander they have , It has a cam lock , Is really heavy . if you rough sanded the gunk off with 40 grit then stepped up to 60 then 80 , THEN VIBE it out .
tacomahardwoodfloors.com
tacomahardwood. is offline   Reply With Quote
Removing glue from hardwood floors - sanding? jbitt Flooring 2 01-20-2010 06:10 PM
Hardwood floor "stains" after sanding moeseegs Flooring 1 10-03-2009 11:01 AM
Rotating Sanding Marks on Hardwood floor Msmtee Flooring 2 07-24-2009 08:06 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
old hardwood on it's last sanding glover10604 Flooring 1 09-09-2008 05:38 PM
