Sanding A Hard Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 12:49 PM   #1
sanding a hard wood floor
can i use a hand sander to sand my hard wood floors to paint them
penny tyree is offline   Reply With Quote
Old 11-24-2011, 12:56 PM   #2
sanding a hardwood floor
I want to know if i can use a hand sander on my hardwood floors to put paint on them
Old 11-24-2011, 01:07 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
I suppose you can. It will be a lot of work and hard to get them smooth.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-24-2011, 01:16 PM   #4
Rewards Points: 582
why would you want to ....TAKE LONG TIME HARDWORK....how about floor sander?
Old 11-24-2011, 01:37 PM   #5
DIY staff
Rewards Points: 7,174
I've done it with a 4" belt sander---very slow and very expensive --at $4.00 a belt---but it can be done.
Start with 36 grit and work up to 100 or 120 grit---random orbit for the edges----scraper for the corners.
Old 11-24-2011, 04:33 PM   #6
Too Short? Cut it Again!
Rent an orbital, not a drum, floor sander. They use a fair amount of paper but they are fairly easy to use and it is pretty hard to screw things up like you can with a drum sander. You just keep switching to finer grid papers until the surface is ready for finish. They also sand most all the way to the edges.
Make sure you set all exposed nails heads first.
The Following User Says Thank You to user1007 For This Useful Post:
ben's plumbing (11-24-2011)
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 07:30 PM
Installing 9mm bamboo over 9mm wood floor and concrete hellobritt Flooring 4 08-30-2011 10:35 PM
Floor insulation, cellulose vs hard foam Arky217 Flooring 0 12-23-2010 11:44 PM
problem: Water on wood floor during refinishing HouseMgr Flooring 2 08-15-2009 10:19 PM
Hard Wood Floor Refinish Question kwiatkow Flooring 4 01-28-2009 07:01 PM
