Old 04-17-2011, 05:36 PM   #1
Sanding concrete floor
I just recently had a water leak and the plumbers had to go through my living room floor to get to leak under slab. They filled the hole back in with concrete but now it's a little to high and not level. I want to put new flooring down but need the concrete patch to be sanded down first. Does anyone know what I can use to sand the patch down so that it will be level with the rest of the floor?
Kaustin is offline   Reply With Quote
Old 04-17-2011, 06:57 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
not suprised with the bad patch job, i run into this a lot. i would use a diamond cup wheel on an angle grinder if it is a small enough area. a vaccume attachment works good indoors to help control the dust. larger concrete grinders with complete dust containment systemes can be rented if the area is too large for the hand held grinder
mustangmike3789 is offline   Reply With Quote
Old 04-17-2011, 08:48 PM   #3
King Construction Inc.
couldnt have been put any better
nking is offline   Reply With Quote
covered concrete porch..what kind of floor? captjackny Flooring 4 02-26-2010 11:47 AM
Concrete stain on painted sloped floor ur_real_dad_21 Flooring 4 01-09-2009 12:38 PM
cold concrete floor RuthP Flooring 4 02-03-2008 11:13 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 09:01 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
