Sanding In Between Varathane Water Based Floor Finish? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-08-2008, 11:06 AM   #1
Sanding in between Varathane water based floor finish?
Greetings all,
I just put down my first coat of Varathane Water Based diamond floor finish.
Apparently I should sand before applying the second coat, exactly what should I use for the dust clean up? Mineral spirits is what I read for oil based finishes, but I'm not sure about water based. I also could use a tack cloth, but that just doesn't seem to pick up too well...
Joony is offline   Reply With Quote
Old 07-09-2008, 08:10 AM   #2
I would use my shop vac with a good filter and tac rag.
JohnJak is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
Primer Sealer Oil or Water Based? petey Painting 7 05-11-2008 07:11 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
