Old 01-01-2012, 03:06 PM   #1
Is sanding between layers necessary?
Dear experts,
I am renewing an old stairway. I just put the first layer of clear water-based polycrylic. My question is, do I really have to sand it with fine sandpaper between layers? Because I am not sure even how to do it without special machinery.
Thanks in advance,
Dmitriy
dpreznik is offline   Reply With Quote
Old 01-01-2012, 03:21 PM   #2
#1 your using totaly the wrong product for floors.
http://www.minwax.com/wood-products/...FQjd4AodV3fkmg
#2 Any polys going to need to be lightly sanded between coats so you need to go buy a sander and plenty of sand paper. A Black & Decker Mouse sander would work best and not cost much.
Any poly for floors will say right on the can on big letters For floors.
dpreznik (01-01-2012)
Old 01-01-2012, 04:32 PM   #3
Thank you for your answer. Unfortunately, I asked at Lowe's for water-based polyurethane, not mentioning that I was going to apply it to stairs.
Now what can I do about the layer I have already applied?
Thanks,
Dmitriy
Old 01-01-2012, 04:54 PM   #4
Tom Struble's Avatar
sand
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Old 01-01-2012, 05:00 PM   #5
Sand it all off.
Old 01-01-2012, 05:00 PM   #6
Is this the one?
http://www.lowes.com/pd_326060-70-MS...d=10151&rpp=24
Old 01-01-2012, 07:03 PM   #7
Yes, Home Depot, and even Wall-Mart sells them.
The paper loads up fast so buy plenty of extra.
Old 01-01-2012, 07:58 PM   #8
Sand it all off.
My I ask one more question? Can I leave the Polycrylic on the vertical boards and only sand it off from the treads?
Old 01-02-2012, 07:29 AM   #9
the Musigician
DangerMouse's Avatar
I don't see a problem with that. You only need the walking surfaces to be heavy duty.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
dpreznik (01-02-2012)
Max number of 15 felt paper layers for low spots (hardwood) diitrii_popov Flooring 2 08-06-2011 02:16 PM
chipping, cracking layers of paint-possible calcimine doornumber3 Painting 9 05-16-2010 11:34 AM
Car Painting and sanding h3llfir3 Painting 19 08-11-2009 10:44 PM
Car Painting and sanding h3llfir3 Automotive Repairs 1 08-10-2009 11:02 PM
Sanding marks.......will they show yummy mummy Building & Construction 9 07-24-2008 12:43 AM
