Saltillo Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 10:59 PM   #1
saltillo tile
I need to make my saltillo floor more level. It is unlevel so when you walk for a while it hurts your feet. Can I grind it down to make it more level and smooth? -then I will reseal .
kathryn holman is offline   Reply With Quote
Old 03-16-2012, 01:41 PM   #2
result
did you ever get an answer on this? I do not like my tile (came with the house) and would like to do the same to make it more bearable.
supersayanx is offline   Reply With Quote
Old 03-16-2012, 07:38 PM   #3
DIY staff
Rewards Points: 7,174
Sorry gang--that is soft unbaked clay--No way that I have ever heard of flattening it.
Buy a tile---attack it with a sander and see if you like the look---They are soft,sun dried clay with a sealer---I suspect the the interior will be prone to voids and unacceptable---
Old 03-17-2012, 11:12 AM   #4
Remodeling Contractor
Mike is completely right. Saltillo is DESIGNED to look that way! I agree, it's an acquired taste. If you don't like the look now - you will not like the look after you tried to "sand / grind" it.
pgc555 is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Installing wood floors over saltillo tile Bloom Flooring 3 07-02-2009 10:42 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
