Sacrificial Plywood Underlayment Before Gluing Engineered Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 12:02 PM   #1
Sacrificial plywood underlayment before gluing engineered floor?
Reading opinions on whether to glue or nail engineered floors is enough to make my head spin. No one seems to dispute the effectiveness of glue in keeping the engineered floor stable and secure.. But the gist of the subject/argument seems to revolve around REMOVAL of the floor, when the time comes (which we all know, will ). Tick Tock. Obviously removal of a glued engineered floor will severely damage if not destroy the ply subfloor..
But what about adding a thin (1/4") 'sacrificial' subfloor above the main subfloor BEFORE gluing the engineered wood? I haven't read about anyone doing this, or even considering it.
That said, I've decided to glue my floors. But not without reservation. The planks are 6.5" width, engineered Hickory. Typical 1/2" thick. I will be using Taylor MS+ Advance adhesive.
Here is my thought:
I currently have a 5/8" thick plywood subfloor, that I have spent countless hours leveling. I am considering nailing (w/ ring shank nails) or possibly crown stapling a 1/4" ply underlayment OVER TOP of my subfloor. I will then GLUE the engineered planks to the 1/4" ply. The idea is that when it is time for floor removal, the 1/4" ply underlayment will come up with the engineered planks, but the 5/8 ply underneath will be preserved, making it easier to replace the floor in the long run (i.e. NOT having to re-level ). The added 1/4" floor height isn't too much of a concern.
Thoughts on this? Am I crazy? How should I secure the 1/4" ply underlayment? What are all the reasons this won't work?
Thanks a bunch for any ideas here.
chesterton is offline   Reply With Quote
Old 12-29-2012, 12:10 PM   #2
Rewards Points: 13,694
The subflooring will still be distroyed when you remove the 1/4 plywood. Ring shanked nails will pull out hunks of wood or just snap off.
Old 12-29-2012, 01:17 PM   #3
So definitely no ring shanked nails. Good point. I want to preserve the 5/8 plywood as best possible so I only have to go down that far when it's re-flooring time.. Crown staples then? Only reason I want to avoid screws is the hope that I'll be able to get under it with a pry bar when the time comes.
How to do plywood underlayment for sheet vinyl ken24 Flooring 23 10-19-2011 03:01 PM
Plywood to increase floor height? Kiwi. Flooring 3 01-17-2011 06:18 PM
Another thread about subflooring & underlayment choices for a first timer DIY tiler pmergler Flooring 8 07-11-2010 02:00 AM
Subfloor and Underlayment Thickness and Materials Joe_NJ Flooring 0 06-07-2010 05:39 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
