Rust Stain On Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 02-07-2009, 05:26 PM   #1
jad
rust stain on tile
The bolts that hold the toilet tank in place were leaking and I replaced them with no problem. The drip was running down the bolt and onto the floor the water rusted the bolt but now the white tile has a rust spot that I can't seem to clean....it seems to gotten into the tile...any idea how I might be able to remove the stain.
jad is offline   Reply With Quote
Old 02-07-2009, 05:49 PM   #2
Floorwizard's Avatar
I wonder if your mistaken....
Is it a glazed tile? Should be impervious to staining if so...
Floorwizard is offline   Reply With Quote
Old 02-07-2009, 06:31 PM   #3
jad
It must be a cheap floor tile.... my wife always hated them and complained that they are impossible to keep clean. Now that I have these rust stains she tells "well we can always redo the bathroom"
I was hoping someone had a trick or some homemade remedy to get the stain out...
Old 02-07-2009, 07:19 PM   #4
Rewards Points: 2,906
Jad:
Try using a Magic Eraser on the stain.
You see, if the tile is porous, or even rough, then the rust may be in tiny crooks and crevices that brush bristles are too large to get into. Magic Erasers are made from a "foam" (kinda) that has microscopically small fibers that will get into tiny cracks that are too small to see.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-07-2009, 07:23 PM   #5
Man of many hats
wrangler's Avatar
Rewards Points: 354
You might also try giving CLR a try if you haven't already.
Man of many hats
wrangler is offline   Reply With Quote
Old 02-07-2009, 07:35 PM   #6
Or a jackhammer.....hey...your wife would be happy
Old 02-07-2009, 07:40 PM   #7
K&B Remodeler/Tile Guy
angus242's Avatar
Oxyclean is a wonderful cleaner for tile & grout.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 02-08-2009, 07:33 AM   #8
Rewards Points: 150
Billy Mays? Is that you?
mike costello is offline   Reply With Quote
Old 02-08-2009, 07:42 AM   #9
ccarlisle's Avatar
Guys, for all we know it could be marble, so recommending CLR or such isn't a good move.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-08-2009, 09:11 AM   #10
Man of many hats
wrangler's Avatar
Rewards Points: 354
Good point, CLR will react with marble, but I would hope that one would read the instructions on any product before using it.
Man of many hats
Rust stain on roof krtw Roofing/Siding 15 10-24-2015 06:17 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
