Running Laminate Floor From Bedroom Into Closet - Flooring - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 10:44 PM   #1
Rewards Points: 260
Running laminate floor from bedroom into closet
I'm installing Pergo laminate flooring in my master bedroom. Should I add a transition piece in the doorway that goes to a walk in closet? I would prefer to just run it as a solid floor throughout and not divide the bedroom and closet. The planks run perpendicular to the closet.
bluefitness is offline   Reply With Quote
Old 05-06-2009, 07:55 AM   #2
Rewards Points: 178
I didn't use a transition strip for the closets. It looks nice without it.
gma2rjc is offline   Reply With Quote
Old 05-06-2009, 11:48 AM   #3
Floorwizard's Avatar
run it straight thru.
Floorwizard is offline   Reply With Quote
Old 05-06-2009, 06:48 PM   #4
LeviDIY's Avatar
Rewards Points: 252
Straight through, just watch those pieces near the door jam... be sure they aren't too small there, if possible, get one piece to cover the entire area (in other words, plan your staggering from the few rows before you hit the door to fall out that way) if you are going horizontally with the door opening, if approaching perpendicular, ensure the end pieces straddle the door in the middle of the piece, not near an end... all for added strength.
LeviDIY is offline   Reply With Quote
Old 05-09-2009, 07:53 PM   #5
Rewards Points: 260
Thanks for the help. I'll run the flooring straight through.
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Laminate Flooring and a Cedar Closet StevenS Flooring 5 03-17-2008 12:28 PM
Framing a Closet & Laminate Flooring Chuck Remodeling 5 01-03-2007 12:35 AM
