Old 11-26-2012, 08:38 AM   #1
rug to wood floor
basement has a rug glued to sub floor. i want to change it to hardwood. what should i expect
aldangeli is offline   Reply With Quote
Old 11-26-2012, 09:32 AM   #2
rug to wood floor
Real hard wood should not be installed below grade, how ever engineered wood floors can be with a vaper barrier and install them as a floating floor.
You can plan on many hours of fighting to get that old carpeting off the floor, then many more hours of try to get all the old glue off.
May want to concider renting a powered floor scraper.
Old 11-26-2012, 10:10 AM   #3
rug to wood floor
sounds like replacing the sub floor might be easier
Cupping of wood floor, need input Vlreddick Flooring 52 10-17-2012 06:48 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Installing 9mm bamboo over 9mm wood floor and concrete hellobritt Flooring 4 08-30-2011 10:35 PM
need advise on refinishing a wood floor EPERRINGTON Flooring 2 03-13-2011 09:12 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 01:48 PM
