Old 11-25-2012, 04:03 PM   #1
Rubber roll flooring for Basement Gym
I am looking to put a small workout room in the basement and was considering rubber flooring:
http://www.rubberflooringinc.com/rub...er-series.html
The room is below grade and the floor has been painted for several years.
Can I assume that I am not likely to have a moisture problem btw the concrete subfloor and the rubber roll?
joabraun is offline   Reply With Quote
Old 11-26-2012, 12:46 AM   #2
If you have never experienced any moisture issues in this room, then it is probably unlikely to be a problem. However, you could ask the manufacturer what their take is on moisture and maybe even get a calcium chloride test to test the moisture to ensure you are within their guidelines.
Awoodfloorguy is offline   Reply With Quote
Old 11-26-2012, 11:15 AM   #3
tape a large piece of clear plastic to the floor. watch it for 1 week. this will tell you about what to expect.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-19-2012 12:51 AM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 01:21 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Konecto flooring LookoutRanch Flooring 23 03-08-2010 04:32 PM
