Rubber Padding - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 09:04 AM   #1
Rubber Padding
Anyone know the best way to get off rubber padding from under an area rug that is now one with the hardwood?
albany is offline   Reply With Quote
Old 02-21-2012, 07:15 PM   #2
Too Short? Cut it Again!
SHARP flat tool to get what you can off. Plastic razor blades in a holder or something like them but larger would be a good choice. Plastic razor blades will come in handy for lots of things and they don't rust like metal ones.
Then try some rubber cement thinner. I think you can still get it in gallons at an art supply store. Work in small areas at a time as it evaporates quickly.
Products for latex paint removal should also work on latex rug backing residue---Goo Gone and Oops come to mind. Krud Kutter is another possibility but I know it comes with a warning that it may discolor hardwood floor finishes.
You should test for colorfastness and other damage to the hardwood floor surface in a small area no matter what you choose.
USE ANY OF THESE PRODUCTS ONLY WITH ADEQUATE VENTILATION!
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 08:15 AM
Rubber Roof Sealant ninghai Roofing/Siding 17 03-08-2010 08:58 PM
Old Rubber Padding on top of Hardwoods GoingINSANE Flooring 5 12-04-2009 08:47 PM
Rubber roof prices tgf40 Roofing/Siding 4 05-27-2008 01:02 PM
Stripping rubber padding off a parquet floor nubee Flooring 1 04-22-2007 01:08 PM
