Rotting Floor Around Toilet Flange - Flooring - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 06:26 PM   #1
Question
Rotting floor around toilet flange
As part of a project, i took the toilet off in order to paint behind it.
What I noticed was there was rust on the bolts and it appears the wax ring may have leaked some. I pulled the flooring up to find the luan flooring was damp. I ripped one section of the luan up and noticed the plywood subfloor was also wet.
I've checked and the flooring is not soft. I'm not sure if i should cut it out and replace it, or spray with bleach and let it dry. I'm somewhat handy, but have never replaced subflooring before, and would like to avoid it unless it is really necessary.
I've attached photos. Can someone take a look and see if it needs to be replaced?
Thanks!
Subfloor
http://imgur.com/sdaval&f8Pwv
Luan
http://imgur.com/sdava&f8Pwvl
cyrusuncc is offline   Reply With Quote
Old 07-03-2011, 06:51 PM   #2
DIY staff
Rewards Points: 7,174
If the sub floor is still solid--wipe with bleach and let it dry----add new 1/4 inch underlayment and reinstall the sheet goods.
That looks like OSB (flake board) if you ever tile that room you will want to add another layer of 1/2" b/c plywood on top.---Mike---
Old 07-03-2011, 07:35 PM   #3
Newly Retired
tuchodi's Avatar
As oh'mike says wipe it down and leave it set for a day or so until it completely dries out. At that point you can check to see if it has any soft spots in it. Did you take up all the flooring?, if so then add the 1/4" plywood and put the floor back down. If you didn't take all the floor up then you have to decide if it is soft or is ok to put the floor back down. Its not that big of a job to cut out the section in question between a couple of joists and put a new piece of sub floor in.
tuchodi is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
tile and toilet flange benshouse Plumbing 3 12-29-2010 06:02 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 05:37 PM
