Old 09-11-2006, 01:19 PM   #1
Rotten End Joists
Hi peeps
I will be laying new laminate flooring soon but first I need to repair the ends of three joists. Whats the best way to do this without taking up the whole floor?? Any links with pictures would be great.
Regards Bill
bill123 is offline   Reply With Quote
Old 09-11-2006, 07:58 PM   #2
Oldguy
Rehabber's Avatar
Rotten End Joists
Are the joists dry rotted out? If so how far, and most important is why? The dry rot must be removed and treated with boric acid to kill any of the organism that is left. Then you can usually sister the joist. Pictures of your problem would help determine how much repair is needed.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 09-12-2006, 09:01 AM   #3
Rotten End Joists
No it is wet rot caused by the ends being sat on top of the brick without any damp course.
Old 09-12-2006, 10:10 AM   #4
Oldguy
Rehabber's Avatar
Rotten End Joists
Same thing 'dry rot" is caused by dampness.
Old 09-12-2006, 02:00 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
Rotten End Joists
Sister pressure-treated joists of the same size to the damaged joists.
Turn the "crown" of the boards up. No need to treat the old joists with anything unless they're infested with termites.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 09:50 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
Need advice...rotten floor joists on house I'm buying strngelitlgrrl General Discussion 5 08-01-2005 10:14 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
