-   -   Rotten End Joists (http://www.diychatroom.com/f5/rotten-end-joists-3882/)
bill123 09-11-2006 12:19 PM
Rotten End Joists
Hi peeps
I will be laying new laminate flooring soon but first I need to repair the ends of three joists. Whats the best way to do this without taking up the whole floor?? Any links with pictures would be great.
Regards Bill
Rehabber 09-11-2006 06:58 PM
Are the joists dry rotted out? If so how far, and most important is why? The dry rot must be removed and treated with boric acid to kill any of the organism that is left. Then you can usually sister the joist. Pictures of your problem would help determine how much repair is needed.
bill123 09-12-2006 08:01 AM
No it is wet rot caused by the ends being sat on top of the brick without any damp course.
Rehabber 09-12-2006 09:10 AM
Same thing 'dry rot" is caused by dampness.
Mike Swearingen 09-12-2006 01:00 PM
Sister pressure-treated joists of the same size to the damaged joists.
Turn the "crown" of the boards up. No need to treat the old joists with anything unless they're infested with termites.
Good luck!
Mike
