Old 10-15-2011, 03:16 AM   #1
Rotted floor plywood.
What is the easiest way to repair soft rotted wood under vinyl flooring?
dkbdmn is offline   Reply With Quote
Old 10-15-2011, 07:21 AM   #2
Super Moderator
What do you mean by easy?
Remove the vinyl and underlayment--then cut out the rotted subfloor to the joists--Add blocking--add new subfloor---replace the underlayment and vinyl--
If that sounds easy or hard--that's what needs to be done.---Mike----
Floor Doc (10-15-2011)
Help! Rotted Sill Plate Corner 3 Story House petersjse Carpentry 19 11-04-2010 07:19 AM
Rotten Rotted Header! jlatulippe Building & Construction 1 10-06-2010 09:28 AM
Rotted Sill Plate and Joists jhawk4ever Building & Construction 2 08-30-2009 09:03 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 10:43 PM
Help: Rotted wall joists, wall frame plates, subfloor smallblockchevy Remodeling 8 07-22-2008 07:14 AM
