Old 05-05-2012, 02:27 PM   #1
rotted bathroomfloor
In pulling up linoleum flooring, I discovered rotted flooring which will need t be replaced but it will be about 2 weeks before it is done. What do I need to do in the meantime? This area is behind the commode and I do not want to cause any health issues for my family.
grannydebbie is offline   Reply With Quote
Old 05-05-2012, 02:31 PM   #2
Experienced
Jackofall1's Avatar
Hello and welcome grannydebbie, to the best darn DIY'r site on the web.
I wouldn't suspect any health hazards coming from leaving it the way it is for a couple of weeks.
Hope you have another bathroom to use when you are in the repair cycle.
Mark
Best way to repair rotted structural wood member? miamicuse Carpentry 20 11-19-2011 05:30 PM
When to replace rotted stud vs. epoxy ken57 Building & Construction 4 11-08-2011 07:48 AM
Rotten Rotted Header! jlatulippe Building & Construction 1 10-06-2010 09:28 AM
Repairing rotted studs against exterior wall sleepyscout Carpentry 11 07-01-2009 02:31 PM
Help: Rotted wall joists, wall frame plates, subfloor smallblockchevy Remodeling 8 07-22-2008 07:14 AM
