RotoZip For Porcelain Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 05-19-2010, 11:46 AM   #1
zep
RotoZip for porcelain tile
I will soon be installing a shower door on porcelain tile. The RotoZip 5/32" Floor Tile X-Bit, http://www.lowes.com/ProductDisplay?...m&rel=nofollow, looks to be a good choice for this project, although a bit expensive in price. Does anyone have any experience or tips on using this bit to cut holes in porcelain tile? I have some concerns about the bit wandering while trying to initially penetrate the tile.
zep is offline   Reply With Quote
Old 05-19-2010, 01:11 PM   #2
Rewards Points: 190
The only bit I found that would drill hard porcelain is a hollow diamond core bit available online if you Google it. To keep the bit from wandering I wedged a vee shaped piece of plywood against the wall with the bottom of the vee where you want the hole.
zircon is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
