Rotating Sanding Marks On Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-23-2009, 07:30 PM   #1
Smile
Rotating Sanding Marks on Hardwood floor
I had my oak hardwood floors refinished with a semi-gloss finish. Sixteen years ago I had them refinished with a satin finish and I don't remember seeing these rotating marks that I am seeing now. Is it true that the rotating marks will show up because of the semi-gloss finish or should that not be the case. Thank you
Msmtee is offline   Reply With Quote
Old 07-24-2009, 06:07 AM   #2
It sounds like the sander did not do a proper job on the final screening. Those marks should not be visible. They often don't show with a clear finish, but will be very obvious if stained. The only way I know of to get rid of that is rescreen and refinish.
Old 07-24-2009, 07:06 PM   #3
Thanks for your response. I wanted to be prepared for the response I might get from the person who did the work.
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
poly on engineered hardwood floor? Constant Improvement Flooring 3 02-03-2009 11:09 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 10:23 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Air gap under hardwood floor adamrdiamond Flooring 3 06-28-2007 02:36 PM
