Rosin Paper / Advice On Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 03-23-2009, 11:40 AM   #1
rosin paper / advice on installation
I'll be putting down red rosin paper as my underlayment for my wood flooring. What's the best method to attach that to the subfloor? Also read that it should overlap a few inches with the sheet next to it.
I have a stapler, but was afraid of staples causing squeaks later on down the road....
Badger_DIYer is offline   Reply With Quote
Old 03-24-2009, 04:58 PM   #2
Still Learning
Loose lay it or staple just to keep it from moving when working on it. There are really no set guidelines to go by.
HardwoodGuy is offline   Reply With Quote
Old 03-25-2009, 11:30 PM   #3
Rewards Points: 150
loose lay as you lay planks.
johnnyboy is offline   Reply With Quote
Old 03-26-2009, 12:01 AM   #4
Registered User
Rewards Points: 5,516
If it's over a living area, rosin's ok. If over a crawl space, many use a asphalt underlay paper because of the moisture present. (Rosin paper has a permeability of over 50, won't stop any water vapor). Easy read..... http://hardwoodinfo.com/pdf/articles...-_Concrete.pdf Home Depot carries the paper I'm thinking of....not just tar paper, but specifically for under hardwoods. Be safe, GBAR
To use red rosin paper or not with hardwood floors interplexr Flooring 6 03-12-2009 10:36 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
contact paper removal scatterbrain Remodeling 2 07-06-2008 07:57 AM
