Old 10-21-2009, 11:01 AM   #1
Default Rosin paper or 15# felt?
I will soon be laying a 5/16" thick and 3 1/8" wide solid brazilan cherry hardwood floor in our living room, foyer and hallway over 3/4" plywood subfloor. What is best to use under the hardwood - rosin paper or 15# roofing felt and why? Thanks for your input.
Duane 70 is offline   Reply With Quote
Old 10-21-2009, 01:53 PM   #2
ArmchairDIY's Avatar
Rosin paper.
Tar paper or felt can give off an oder. No need to make your living room smell like a blacktop parking lot in August.
Of course this is more of a problem if you have in floor heat.
Rosin paper is the industry standard though.
ArmchairDIY is offline   Reply With Quote
Old 10-21-2009, 03:02 PM   #3
Default Rosin Paper
Roofing felt is sticky whereas Rosin Paper has a very smooth surface. Your wood floor will need to slide ever so slightly on the subfloor to avoid squeaks, the smooth Rosin Paper will allow this movement.
Roofing felt will give you a lifetime of floor squeaks.
MI-Roger is offline   Reply With Quote
Old 10-21-2009, 04:48 PM   #4
The rules I go by are craft paper if the floor is over a basement & felt paper over a crawl space. No need for a moisture barrier over a basement, but necessary over a crawl space where hot & cold meet & can cause condensation.
pinwheel45 is offline   Reply With Quote
Old 10-21-2009, 05:09 PM   #5
Rosin is like your funny papers, except with a red dye not multicolored. If any moisture is below as over a crawl space or laundry , bathroom, etc., you need the vapor retarder that rosin does not have. This is Aquabar-B by Fortifiber at HD: http://www.contractortalk.com/f10/wh...uabar-b-57218/ http://www.fortifiber.com/aquabar_b.html
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 10-22-2009, 05:00 PM   #6
Default 2 for paper - 2 for felt, now what????
OK, so the replies so far are 2 recommend rosin paper and 2 recommend 15# felt. Now what??? Does the felt give off an odor after being laid? Of the replies so far, are any from experienced hardwood floor laying folks? Thanks again everybody for your time and replies on this matter. After looking at many websites, it seems to be split about 50/50 on whether to use rosin paper or felt over a crawl space. So I still don't which to purchase. I will be laying BR-111 5/16" thick solid wood, 3 1/8" wide. I just don't want to make a mistake.
Old 10-22-2009, 05:26 PM   #7
I make my living laying hardwood & have for the last 15 years. If you've got a crawl space, use the felt paper. You need the moisture barrier to prevent condensation leaching into your flooring. Anytime you have hot air meeting cold air, you're going to get condensation. Don't worry about the odor, it really won't be a factor.
Old 10-23-2009, 12:20 PM   #8
I guess these folks Hardwood Manufacturers Association know something and their advice:
http://www.hardwoodinfo.com/display_article.asp?ID=300
bob22 is offline   Reply With Quote
Old 10-23-2009, 02:13 PM   #9
Maybe I misunderstood the original poster, but I thought he was laying over a crawlspace & not on a slab.
Old 11-01-2009, 12:29 PM   #10
CaptChaos's Avatar
Default Sounds Insulation?
If you were installing the flooring on a second floor, would felt paper be a better choice for it's sound insulation if I wanted to reduce noise on the first floor?
CaptChaos is offline   Reply With Quote
Old 11-01-2009, 02:15 PM   #11
If you want to reduce sound, spend the extra 50 cents a food & buy quiet walk & install under the hardwood. It does make a considerable difference.
Old 11-01-2009, 07:55 PM   #12
CaptChaos's Avatar
Wow, great -- never heard of this stuff before. Is this what you mean?
http://www.efloors.com/product/883/1...00-sf-roll.htm
Do you lay this in addition to rosin\felt or in stead of it?
Thanks!
-Cap'n
Old 11-01-2009, 08:19 PM   #13
Thanks!
-Cap'n
That's it. No other underlayment needed.
Old 11-02-2009, 10:31 PM   #14
I have bamboo in two rooms, both over a crawlspace. We had the one room done by professionals, and I did the other. The professionals used craft paper, and I used 30# felt.
I never smelled the felt, other than when it was exposed to the room (before putting down the flooring). I went with the felt in part because the subfloor wasn't totally flat.
Several years later I can see that what the professionals put down is cupping a bit, but mine still looks new. Mine is quieter to walk on. Neither has any squeaks. The cupping isn't a problem -- much less than a mm., but I can see it when the light hits it at an angle. fwiw, the house is wetter under the part that has my work in it.
pyper is offline   Reply With Quote
Old 11-03-2009, 09:15 PM   #15
I didn't intend to cause any confusion, but tar paper (roofing felt) only would causes an oder issue if you have under floor heating. And even then it may not.
I threw that in my original post because I wanted everyone to be aware that it could possibly be an issue.
"It looked good on paper, but paper is funny that way"
ArmchairDIY
More On This Topic
On behalf of Expert Village, my name is Natalia Paruz, also known as "the saw lady." You can find me in New York City, and today I'm going to teach you how to play a saw. If the blade gets rusty that takes away from the sound, so you want to keep your... Read More »
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
Hi! I'm Karina Fraley for Expert Village and today I'm showing you how to make a felt photo frame ornament for your Christmas tree. We've gone ahead and gotten our fabric ready with the backing and we've cut out this front, the facing. This we're... Read More »
Violin Rosin for Beginners
Violin Rosin for Beginners by Expert Village
Normally, when you pick out a rosin at any music store; you'll find that it comes in a round cake, or a square cake; probably even a rectangular cake. My particular rosin is a round cake; wrapped in a fine cloth. This protects the rosin from drying out... Read More »
Hello! On behalf of expertvillage.com my name is Eileen Duffy, and today I’m going to talk to you about how to start your own handbag company. The next step is to have a beautiful professional label name that you have to put inside every bag. I had... Read More »
Felt Paper and the Sun. Valley problems hartkem Roofing 1 07-22-2009 05:57 PM
RoofGaurd vs Felt paper GerryinBelleRiv Roofing 5 06-30-2009 09:36 AM
To use red rosin paper or not with hardwood floors interplexr Flooring 6 03-12-2009 12:36 PM
Does felt paper allow a house to breathe? bluefitness Building & Construction 2 02-08-2009 10:42 AM
Rosin or felt under strip flooring when you have faced insulation below? RolandOG Flooring 2 11-20-2008 11:16 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
