Old 11-19-2008, 03:14 PM   #1
Rosin or felt under strip flooring when you have faced insulation below?
I've searched and I keep reading conflicting information. If I have a vapor barrier on the insulation under the subfloor then why would I need to have a moisture barrier under the flooring? The label on the rosin paper said it was a moisture barrier but I have a hard time believing it really does much beyond minimizing squeaks.
Am I wrong? Should I be putting felt or rosin under the flooring? At the moment I'm planning to put the rosin under it for the squeaking, assuming I'm right that it's not really a moisture/vapor barrier.
RolandOG is offline   Reply With Quote
Old 11-19-2008, 04:21 PM   #2
I"m putting down 900sqft of engineered HW this week. I got 15# felt as opposed to rosin paper. Better safe than sorry, why skimp when it only costs a few dollars more...
Thanks,
Chris
poolecw is offline   Reply With Quote
Old 11-20-2008, 10:16 AM   #3
I can see that point. However, I’m still wondering why it would be necessary if I already have a vapor barrier below the OSB. I’m not trying to be cheap or lazy on this, I’m just wondering why you’d double up the barrier on the floor. You’re not supposed to double up a vapor barrier on a wall because moisture can get trapped between the two layers. Why would it be okay on the floor?
More On This Topic
Hi! My name is Joshua Lindsey with CFM Science Building Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The first thing we are going to look at is the overall alignment throughout the house. What... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this house. So just to clarify this right here is going to have drywall on the face of it. We've... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next one that we are going to cover on this list is going to be the air barrier and all... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. Now that we can see an insulated home, we want to take another look here at the top of this... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk here a minute about compression. Compression in an insulation inspection is... Read More »
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 14 01-18-2010 08:52 PM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 02:23 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
faced or unfaced insulation wiggs Building & Construction 5 04-19-2006 06:50 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
