I'm a very green DIY'er who is going to attempt at redoing my kitchen floor. I have done some tile installation in the past, so I understand the general process and principles. What makes this job somewhat intimidating is the kitchen floor itself (as it is now). Currently there is the subfloor, a layer of plywood, some linoleum flooring (original to the house) I think, another layer of plywood, and the tile on top of it. Due to the added layers there is a height transition of about 3/4 of an inch between the connecting floors. Also, the kitchen cabinets are installed on top of the tile, along with the island in the kitchen. I do not want to move the cabinets, so here is my plan.
1. Disconnect dishwasher/stove
2. Remove island (unscrew it)
3. Prep the cabinet bases with a couple layers of painters tape to prevent scratching.
4. Use a dremel saw (or something similar) to cut away at the tile around the cabinets.
5. Break off the tile using a mason's chisel, and or a sledge hammer/canvas tarp to control the breakage.
6. Use the saw again to cut out the plywood around the cabinets.
7. Pry plywood out (it appears to be nailed in)
8. Assuming there is a linoleum floor, apply durarock/backerboard w/e to the original floor using thinset and galvanized screws (whatever the ones are that dont rust).
9. Apply a fiberglass tape to the joints in the new base flooring, and then seal them up.
Then I get to applying my tile. That part im confident in.
Based on the steps I described is there something I am missing or shouldn't do?
Any advice, or feedback, you have would be great.
