Rookie Ceramic Tiling Mistake! - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-20-2011, 02:57 PM   #16
Military Mom of 4
Snav's Avatar
If you used a chisel you wouldn't have to worry about soap. . . it's doesn't need to be bathed and cleaned and glistening - it needs to be abraded into submission!
I've also had decent success with a heavy-duty pumice stone (that's sold in the hardware dept) . . but a chisel or screwdriver is ideal.
Howh much do you have to do anyway - linear feet wise?
If you scrape 6" clean within two-minutes time then how much could you have gotten done since you started this thread?
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following User Says Thank You to Snav For This Useful Post:
sandmoran (11-03-2012)
Old 12-20-2011, 03:45 PM   #17
lol unfortunately I also have a day job and a very needy girlfriend All jokes aside, I didn't think a pumice stone would work considering how abrasive it is. So in your estimation, it wouldn't scratch the tile? I wanted to go the cautious route and continue using the Adobie pads, but as you know, they get torn up in a hurry. The "birds eye" depth is just fine right now - well under 40% in height, but its the crap on the side that is giving me fits.
I think my best bet is what you guys (and when I say guys, I mean it as a uni-sex term) have already recommended in terms of tools. Sharpening my tools with a grinder will be my next step I think as they've dulled up quite a bit. Will keep you posted. Thanks for all your help!
idlewatcher is offline   Reply With Quote
Old 12-20-2011, 04:13 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Had enough yet?
XXX
Old 12-20-2011, 07:16 PM   #19
Military Mom of 4
Snav's Avatar
The pumice stone I'm referring to is made for cleaning uck off of ceramic and porcelain (like cook tops - etc) . . . you're right: it's cheap and efficient if it doesn't abraid your surface. If you're using porcelain tile I'd say go for it - anything else and I'd say not to.
If time is the issue you could really lay out an area rug - cover things over - and fiddle with it over time or after Christmas.
Ceramic tiling Naz1298 Flooring 6 10-25-2011 07:20 AM
Ceramic Tiling Help sean651 Flooring 8 05-27-2011 05:46 PM
Ceramic tiling on the cheap! Red Squirrel Off Topic 2 07-25-2010 06:26 PM
Rookie mistake - question about smoothing out an "oops" brich Carpentry 12 04-08-2010 08:38 AM
Ceramic Tiling on a Slab nsb318 Flooring 3 03-01-2007 02:23 AM
