Roofing Tar On Basement Concrete Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-04-2007, 02:02 PM   #1
Question
roofing tar on basement concrete floor?
I scanned the previous posts about removing tile adhesive/cutback, and am wondering whether the advice would be much different for what I think I have. I pulled up a plywood subfloor in my basement and found (moldy) tar paper underneath, and the concrete covered in shiny, brittle, black tar-stuff. It wasn't used as an adhesive, so I'm thinking he used roofing tar as waterproofing. Whatever it was didn't work, obviously.
I really didn't want to put another subfloor down, just clean up and paint the concrete floor. But I need to figure out how to deal with this tar-stuff. Melt it, scrape it, disolve it? Cover it with self-leveling concrete & hope that adheres? Give up & put down a new subfloor? Give up and learn to like blue plastic tarp flooring?
thanks!
bluebee1314 is offline   Reply With Quote
Old 11-04-2007, 03:20 PM   #2
Guest
Guest
Posts: n/a
The only problem with asphalt products is that it's very difficult to get anything to stick to them other than more asphalt. We've dealt with it on asphalt roof coatings before. Usually after it's weathered a few years we can coat the roof with an acrylic DTM and it'll stick fine. Oils will peel. So at the very least you'd want to go with an acrylic floor coating. Even then you'd have to some how strip the floor. Soda or sand blasting is probably the most thorough option though certainly not the easiest.
Old 11-04-2007, 06:13 PM   #3
Firefighter/Paramedic
tyler101's Avatar
You can use a scarifier to shave the surface down. The rental is about $90 a day.
tyler101 is offline   Reply With Quote
Old 11-05-2007, 07:19 PM   #4
Thanks, guys! Based on what you've said, and on what I think I can do (and tolerate), I'll clean it up as best I can then put something like dricore over it. Just wanted to make sure I wasn't missing anything.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
waterproof basement floor?? patnshan Remodeling 3 09-07-2006 02:58 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 06:06 PM
cutting a concrete basement floor Rembrandt Introductions 1 10-23-2005 01:58 PM
