Roofing Felt - Flooring - DIY Chatroom Home Improvement Forum
Old 01-17-2013, 05:23 PM   #1
Roofing Felt
Hello,
I am flooring a basement that is sloped to a center drain. the slope is about 1 1/2 inches. the diameter of the circle that the slope starts is about 15 ft. Can i use roofing felt to build up the low spots and make it level? Or is self leveler the way to go? (Keeping the drain open btw)
Bigin429 is offline   Reply With Quote
Old 01-17-2013, 05:31 PM   #2
DIY staff
Rewards Points: 7,174
You will wrinkle it up walking on it.
I suggest you put something on top of it to protect it from damage.
Seriously---what are you doing? Fill us in and you will get a serious answer.
Old 01-17-2013, 05:34 PM   #3
Rewards Points: 12,794
Might want to add what kind of flooring your trying to use.
Old 01-17-2013, 06:01 PM   #4
Sorry,
Looking at Laminate Flooring, click locking kind. Live in Central PA. I guess what I am really asking is, is self leveling concrete/compound the only way to level a basement floor? I know its expensive so I was just asking around.
Old 01-17-2013, 07:34 PM   #5
DIY staff
For floating floor I have heard of good results using shingles and roofers felt---
I never tried it---I'm more of a ceramic tile guy--so SLC is my go to product---but it is pricey ,
Let's see if someone with real world experience chimes in----
Old 01-17-2013, 11:19 PM   #6
#1 I'd never suggest using an laminite below grade.
Old 01-18-2013, 03:39 PM   #7
Rewards Points: 3,342
+1 to what Joe said, never use laminate flooring below grade, use engineered flooring instead.
Canarywood1 is offline   Reply With Quote
Roofing Felt Installation Question MrUnderhill Roofing/Siding 3 09-27-2012 08:38 AM
Leveling an old subfloor - sand vs roofing felt whitesjtaa Flooring 5 05-07-2012 06:57 PM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 05:49 PM
is roofing felt necessary for a 8x12 shed? jmoney Building & Construction 8 06-16-2010 04:46 PM
Roofing felt mattflytx Roofing/Siding 2 09-10-2007 12:01 AM
