Rippled Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 04-12-2008, 04:57 PM   #1
Cool
Rippled Carpet
In less then a week, two different sections of my wall-to-wall carpet developed a ripple in them. Both are next to or near a doorway and both are near a seam. What causes this?
The carpet has been down for about 2 or 3 years and no other problems have cropped up. There is no wear on the carpeting either. The carpet is a mid-grade nylon carpet.
Can the carpet be re-stretched? Is this a job for an amateur or is it easier to call a pro? Will they come out and restretch existing carpeting?
Any advice is appreciated.
panhandlion is offline   Reply With Quote
Old 04-12-2008, 10:10 PM   #2
Contractor
Sounds like it wasn't stretched tight the first time. If the seams aren't coming loose, it should be able to be pulled tight again. If you need to ask about whether you need a pro or not, you have obviously never kicked in a carpet. Go with a pro.
Teetorbilt is offline   Reply With Quote
Old 04-14-2008, 09:58 PM   #3
remodeling pro
The carpet can be restretched, but as Teetorbilt says, hire a pro. It may look very simple watching a carpet layer stretch a carpet tight, but there is much of a learned knack to knowing where and in which direction to pull it for it to lay flat. There is also the posibility that a seam will have to be cut and remade to get rid of the slack.
Knowledge gained from personal carpet restretching failure.
troubleseeker is offline   Reply With Quote
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
Carpet - different colours in 2 rooms tonyt Flooring 1 09-09-2007 04:21 PM
