Ripping Up Ceramic/Thinset - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 07:43 AM   #16
DIY staff
Rewards Points: 7,174
I recently finished a 32 bathroom commercial job----some were set in epoxy----the demo was costly---
I like the final look----your efforts paid off----a good electric chipping hammer is expensive----glad you found a cost effective alternative.
It's not fun to buy a special use tool and then only use it once-----
Old 03-04-2013, 07:47 AM   #17
Rewards Points: 87
Thanks - I only felt comfortable enough to tackle this project because of the advice i get here in this forum. The air hammer was like $20 at Lowes (though I found out Harbor Freight sells the same model for $10) and I borrowed a large enough compressor for the job so my total cost for the demo that wasnt anticipated was only the $20 and my time. I kept the air hammer in case I ever need it again but you're right - nothing more frustrating than buying a tool (or tools) that you know you'll likely never use again.
ssgtjoenunez is offline   Reply With Quote
The Following User Says Thank You to ssgtjoenunez For This Useful Post:
oh'mike (03-04-2013)
Old 03-04-2013, 11:41 AM   #18
Rewards Points: 87
I also forgot to mention that this time around I used Grout Boost instead of water when mixing the grout. Supposedly this means I do not have to use an external sealant as this is supposed to seal it when you lay it down.
Anyone else used a similar product? Do you recommend it? I'm about a week from sealing the work I did in the kitchen but am considering not sealing this one seeing as how I used the boost.
Thoughts?
Old 03-04-2013, 12:36 PM   #19
Rewards Points: 2,516
Like seeing you planned on placing the toilet flange ON TOP OF the finished floor(diagram #1).
Good call. Others may and will disagree. It is an ongoing debate.
Ripping up Ceramic/Thinset-closet-flange-flush-not.jpg
hammerlane is offline   Reply With Quote
Old 03-04-2013, 12:37 PM   #20
Rewards Points: 87
I'll be replacing the existing toilet and don't know what the new one will cover so this was the only option to ensure it was done right.
Old 03-04-2013, 01:48 PM   #21
Rewards Points: 87
I looked at it again and actually the flange is already in place and I tiled around it (option 2 on your diagram) which would have me putting the wax ring and toilet on top of the existing flange.
What is the benefit of doing it the other way?
Old 03-04-2013, 03:54 PM   #22
Never ending debate. See here for some reading: post #9 will have additional links
Basement toilet redo, toliet flange question
Help Please Baseboard / ripping out paneling roti Remodeling 7 10-22-2012 05:27 PM
ripping off esisting roof mn-johnson Building & Construction 2 05-15-2011 07:26 AM
Mortor bed under bathtub: what about 15 years from now when ripping out tub? lazzlazz Kitchen & Bath Remodeling 6 05-20-2010 08:56 PM
Ripping up Vinyl Flooring harmony Flooring 5 02-26-2008 04:50 PM
ripping safely with a circular saw bobbyC777 Safety 6 02-20-2008 09:16 AM
