Old 02-08-2008, 11:24 AM   #1
Lightbulb
ring shank nail removal
how do you remove ring shank nails from existing hardwood flooring.??
the flooring is installed in my house, someone installed subfloor over the hardwood flooring, and I am trying to refinish the hardwood.
some of the nails come out with the pry bar, but others the heads come off..
steaed is offline   Reply With Quote
Old 02-08-2008, 02:43 PM   #2
Can you post a photo?
redline is offline   Reply With Quote
Old 02-08-2008, 03:33 PM   #3
I called my brother and he said to use nippers and roll them back...seems to work great
Old 02-08-2008, 03:36 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
I am NOT a progfessional floor finisher, just a long-time DIYer.
Do not try to pull ring shank nails out of wood as it will more than likely damage the wood badly.
The best solution, in my opinion, is to sink the ring shanks slightly below the finishing level with a straight punch the size of the nailhead, and then fill the holes with matching colored wood putty before sanding and sealing.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-08-2008, 04:32 PM   #5
Tileguy
Bud Cline's Avatar
If your intention is to refinish then pulling them out will only cause more damage to the remaining floor. Mike is correct, cut/break the heads off and punch the shank into the floor.
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 15 02-20-2008 03:23 AM
Best Practices for Framing Nail size jms5883 Remodeling 7 01-31-2008 12:37 PM
nail removal on fascia big blue Building & Construction 4 10-07-2006 10:42 AM
Finishing nail removal bklauer Carpentry 6 09-05-2006 08:13 AM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
