Ridges On A Concrete Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 05:40 AM   #1
ridges on a concrete floor
I am planning on laying an epoxy finish on my garage floor. I was told that any unevenness in the concrete would show so I decided to use a self-leveling underlayment. This was the first time I've tried something like this and apparently I did something WAY wrong. The mixture looked to me like really thin concrete. When I poured it, it seemed to flow really easily. I had a friend pouring while I used the squeegee to get the concrete into all the corners and somewhat level it so that it can finish leveling itself off. When I looked in the next morning, I noticed that there are ridges everywhere from the squeegee. It has been several days now and they are still there. They didn't level out. Now I have two questions. 1. What did I do wrong? 2. How can I fix it? Thanks.
Blake
P.S. Total working time, including mixing the second bag was around 20 minutes.
SBlakeS is offline   Reply With Quote
Old 02-05-2010, 06:02 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
"self-leveling underlayment".... what brand?
you may need to 'sand' it smooth.
DM
Old 02-05-2010, 08:11 AM   #3
It was MAPEI Novaplan 2. Do you mean "sand" it smooth with a floor grinder?
Old 02-05-2010, 08:44 AM   #4
the Musigician
possibly, or you may have to redo it. maybe it wasn't thin enough to self level?
i'm hoping the guys will chime in here any time.....
DM
Old 02-05-2010, 08:53 AM   #5
I just looked on the MAPEI site and they have self-leveling underlayment and self-leveling topping. Should I have used a self-leveling topping?
Old 02-05-2010, 08:56 AM   #6
the Musigician
i'd guess underlayment since you're going to add epoxy? not too sure on this one.
love the different looks you can do with epoxy though, wise choice.
DM
Old 02-05-2010, 08:59 AM   #7
Thank you. I'm really excited to do this. Just need to get the floor looking right first.
Old 02-05-2010, 10:46 AM   #8
jlhaslip's Avatar
Rewards Points: 2,140
grinder with a carborundum (sp?) cup stone to take off the high spots first.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-05-2010, 11:01 AM   #9
If I do use a floor grinder, will it eat quickly into the floor and possibly cause pits or will it slowly grind material away?
Old 02-05-2010, 12:14 PM   #10
Also, I have 2 options to rent. A 7" hand-held grinder or a 22" floor buffer style grinder. Which should I get? Also, how do I grind next to walls and in tight spaces?
Old 02-05-2010, 04:19 PM   #11
Any ideas? I'm really lost on this one and really need the help. Thanks.
Blake
Old 02-06-2010, 06:26 AM   #12
Rewards Points: 4,648
we use several things - oscillating floor sander - 4 & 7" diamond cup wheels on hand grinders - swing buffers w/screens &/or diamond pads - walk-behind 2-head'd grinders - depends on the ridges - topping was the correct mtl, not underlayment - my advice is grind it all of & begin anew,,, diy projects aren't necessarily as easy as the literature - dvd's - brochures - w-sites but this is how you learn,,, fairly difficult to gain critical experience & knowledge when everything goes ' RIGHT ' especially when the goal requires 'em
Old 03-25-2010, 12:59 PM   #13
Thumbs up
Grinding concrete ridges
Been doing epoxy garage floors since 2004.
You will need to grind the floor smooth with a diamond grinding wheel. Be careful, though, it is all too easy to leave grinder swirl marks in the surface.
ALSO, don't scrimp. It is absolutely necessary to get a grinder with an attached vacuum to suck up the concrete dust. It is nasty stuff you don't want to be breathing. I'd also wear a dust mask.
The epoxy and decorative chips hide lots of sins when the chips are applied at 100% coverage but they don't hide everything.
Patrick Dowd
California Concrete Restoration
http://www.squidoo.com/epoxygaragefloors
calconcrete is offline   Reply With Quote
Concrete stain on painted sloped floor ur_real_dad_21 Flooring 4 01-09-2009 11:38 AM
Removing Concrete Ridge and Ground Protection on Ground Floor RayIII Building & Construction 1 10-09-2008 02:36 PM
cold concrete floor RuthP Flooring 4 02-03-2008 10:13 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 08:01 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
