Reuse Mud Bed Or Replace With DuRock? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-02-2013, 04:32 PM   #1
Reuse Mud Bed or Replace with DuRock?
I am new to the site and new to flooring. We are putting a combination of 20*20" and 13*13" tiles in our entry way. I removed the existing small tiles that were laid in the mid 70's and am wondering how I should proceed.
Do I add a leveling agent over the existing material, or do I remove it down to the subfloor and add durock?
The subflooring is 3/4" plywood over 2*10 joists that are 16 inches apart.
I've attached a couple pictures to give you an idea of what I'm looking at. My gut tells me that I'll need to rip this up and start over, but I don't want to do any extra work if there's little/no benefit.
Reuse Mud Bed or Replace with DuRock?-photo-11-.jpg   Reuse Mud Bed or Replace with DuRock?-photo.jpg
rtastad is offline   Reply With Quote
Old 10-02-2013, 06:57 PM   #2
So a little more research confirmed that I needed to remove the "Jersey" whatever (mortar bed with mesh inside). I've started this process; it's definitely not fun or easy.
Will I need to add a layer of plywood? If so, 1/2 or 3/4". Again the existing construction is 3/4" plywood over 2*10 joists that are 16" on center.
Thanks.
Old 10-03-2013, 09:22 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 412
Hi,
I answered at your other thread and thought it seemed familiar.
One question for you, does this area and the kitchen in the other thread meet someplace?
BTW, that is not a Jersey Mud job. That is a standard mud job.
I would think you'd want to be at the same level as the other room. If so, add 3/4" ply then your 1/4" Durock, if that's what you're using.
Jaz
JazMan is online now   Reply With Quote
Old 10-03-2013, 09:56 PM   #4
Same house. (Big project...)
The other thread is my kitchen. This is the entry on a split foyer house. So no need to correspond with another floor level. I have removed half of the cement so far and will drop some 3/4" plywood and Durock when ready.
Tags
durock , floor leveling , mud bed , tile
Gap between tub and durock (not lip) megablok Flooring 19 04-05-2012 10:15 AM
replacing tile on durock, how to repair part of durock board already on floor? gared@roadrunne Tiling, ceramics, marble 1 01-15-2011 05:01 PM
Installing Garage Door Opener... Replace or Reuse Hardware? flipjarg General DIY Discussions 2 12-05-2010 03:38 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
